Old 03-14-2008, 12:36 PM   #21 (permalink)
Anubis's Avatar
Originally Posted by eh_civicracer View Post
a stock si with slicks can do low 14s to high 13s. it's all on the driver.
I will give it to you that anything IS possible, but taking a high 14s car into the 13s will take more than tires.
Anubis is offline
Old 03-14-2008, 10:38 PM   #22 (permalink)
yeah 13's won't happen without i'd say full bolt ons hondata reflash and a great set of tires. or some drag radials.
vtecmike1 is offline
Old 03-14-2008, 11:15 PM   #23 (permalink)
02SilverSiHB's Avatar
if you were more consistant with your shifting plus powershifted you would had seen 14 flat. that was a good launch. you just wasn't consistant with your shifting. work on being consistant then try again.
I was consistent...I have enough traction issues...if I had slicks....yeah, I would have seen a lower 14...that's a no duh.
And yeah, some people are hitting 13's with i/h/e and reflash...mostly in sub degree weather and those tracks in NJ must be slightly down hill with the wind in the back helping to push...lol. Ah, I'm just jealous I guess.
02SilverSiHB is offline
Old 03-15-2008, 03:59 PM   #24 (permalink)
Jeremy
hey well about tires I just got a set of bfgoodrich g-force tration t/a drag radials 225/45/R17 and I bogged horribly and had a 2.231 60' I was not happy.
batrup99jeremy is offline
Old 03-15-2008, 09:13 PM   #25 (permalink)
ouch...that sucks...did you bog after your take off? I noticed that happened a couple of times...wonder if it's the DBW
Old 03-15-2008, 09:46 PM   #26 (permalink)
Jeremy
yea i bogged down to just above 3000 and i have the reflash and nitrous kicks in at 5000 I only had two runs and i was dumping the clutch. how could i fix this any ideas???
I was thinking i could turn the nitrous down to 4000 so it when kick in right when i launch, or i was thought instead on dumping the clutch i could just ease it out until it reads 1 MPH then rev it alot higher then drop the clutch. I had no problem spinning the tires for my burn out...
robber steals prosthetic foot from girl.... 2nd time webby Water Cooler 22 04-22-2008 07:57 PM
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
Steele, Alabama drag strip meet (not just 8thgen)10 second civic GETxERxDONE Introduction & Pictures 8 03-26-2007 06:40 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
Rims and tires for the drag strip Zesti1 Wheel And Tire Upgrades 3 06-08-2006 11:53 AM
