Old 03-01-2008, 12:52 AM   #1 (permalink)
Went to the strip yesterday.
I went last evening to see if I gained any.
Don't know if you can see the 5 runs clearly.
55-60 degrees - front tires 20psi - rear tires 40psi - VSA off - all runs were launching at 5500 rpms (neutral rev limiter). Almost a full tank of gas (a nono I know).
Sorry only the #1 run vid, camera mount broke at the track (GRRRRR). The rest of vidz was pointing at the inside of the roof (no need to see that lol).
VID of fisrt run here> Almost 10mb http://www.freedomcomputers.net/civi...nddragtrip.wmv
There were alotta Mustangs there with superchargers and big shots of N2O.
#1 very little wheel hop with wheels spinning
.059 <----best reaction
2.477
6.429
9.674
76.65
12.437
14.779
96.57
#2 red light - very little wheel hop with wheels spinning
-.050
2.301
6.251
9.529
76.27
12.296
14.640
96.49
#3 I reacted slow - Ecutout OPEN (god it sounded NICE!) - Lotta wheel hop - Major wheel spin in 1st and when shifted to 2nd rpms dropped to 4000 (was going to slow). I think by opening the Ecutout it gave me more power and I didn't adjust the clutch release time for the added power.
.458 <----snoring
2.481
6.689
9.976
75.87
12.757
15.105
96.34
#4 BEST RUN of the night - Ecutout open - releasing the clutch slower - very little wheel hop with wheels spinning.
.169
2.218 <-----best 60 footer
6.180
9.419
76.70
12.181
14.519
96.73 <----highest mph
#5 very little wheel hop with wheels spinning, THEN grinded 2nd gear! Phawk! lost .5 of a second.
.311
2.258
6.477
9.829
74.69
12.636
15.005
95.61
If I had some DR's or slicks, I think 13's would have been reached. I just could not get the tires to grip in first and part of second. Running on optional summer tires. I guess I should have kept those 16's with BFG DR's on them.
bioevolve is offline   Reply With Quote
Old 03-01-2008, 12:56 AM   #2 (permalink)
what are the mods... then i can say if these are good times or not
Old 03-01-2008, 01:05 AM   #3 (permalink)
slow4drsi's Avatar
yeah those 60 ft are terrible , that's like 13's with 2.0-2.1 60ft
slow4drsi is online now   Reply With Quote
Old 03-01-2008, 01:06 AM   #4 (permalink)
2007 Sedan Si
engine
Two P2r Throttle Body Gaskets
P2r Throttle Body Spacer
Hondata Intake Manifold Gasket
Mobil 1 Synthetic 5w-30
Hamp Oil Filter W/ Crush Washers
Spoon Jdm Motor Oil Magnetic Drain Bolt
Dc Race Header V2
O2 Defouler 18mm Spark Plug Non-fouler
Tb Coolant By-pass
Odyssey Battery Ody-pc680mjt & Diy Tie Down
Poorman’s Mod Box W/ K&n Filter
Ingalls Etd
Ingalls Power Stick
Nst 3 Pulley Kit
Hondata Flash
E-cutout
Buddy Club Condenser Kit
Ebay 7 Wire Grounding Kit
transmission
Spoon Jdm Tranny Oil Magnetic Drain Bolt
Amsoil 5w-30 Mtf Syncromesh
Corsports Shifter Cable Bushings
Edelbrock Ss Clutch Line
Twm Short Shifter
Twm Shifter Bushing Kit
suspension
Tc Sportline Front Stb
Tanabe F 4-point Under Brace
Progress 22mm Rear Sway Bar Kit
Megan Front Lower Tie Brace
Megan Rear Lower Tie Brace
Four Corsport End Links V2
interior
Tint 35% Front 20% Rear
Blue Led Dome Lights X3
Stainless Steel Dead Pedal
Defrost A/c By-pass Mod
Innova 3030 Obdii Scanner/reader
Cruise Cam Camera Mount Headrest
Ram Laptop Mount
Auterra Dyno Scan Kit
7” Rear View Monitor W/ Night Vision Camera
1250/2000watt Dc Tp Ac Power Inverter
Laptop W/ Accessories
exterior
Fmiaa Horn Low Tone
Old 03-01-2008, 01:08 AM   #5 (permalink)
ahh... with those mods u should be into the 13's... what track did u go to?? seeing as ur in Florida as well
Old 03-01-2008, 01:10 AM   #6 (permalink)
Bradenton
Old 03-01-2008, 01:13 AM   #7 (permalink)
kk... not bad times... but u should definitely be closer to 13's... have u dyno'd ur car yet??
Old 03-01-2008, 01:15 AM   #8 (permalink)
Been wanting to, nothing open on the weekends here. I can't get off work to get it done. I wanna goto Moroso but haven't had the time.
Went to the strip yestderday (results inside) Matauz Autocross & Sanctioned Drag Racing 42 11-20-2007 01:16 PM
Sold the Civic yesterday... stevieray Introduction & Pictures 14 05-24-2007 05:37 PM
Fog lights installed yesterday, found plastic pieces on floor letsgoflyers81 Garage 11 10-25-2006 02:13 PM
Just got back from the Drag Strip... UncleSid Autocross & Sanctioned Drag Racing 5 08-31-2006 10:10 PM
Yesterday 10,000 Miles, Today A car backs OVER my hood fesersoft Garage 15 02-05-2006 03:59 AM
