#723 (permalink) |
Congrats on your first D.C. season! We've got a great crew in STX...but you'll need to remove that TBS first. That technically puts you straight into SM, as was previously stated, in STX you can't do anything after the throttle body. I won't protest you...unless you start winning. But it would probably be best to be legal.
The Hondata should be legal as I'm assuming it's just a tuning program. As long as it does not act as a standalone control, there should be no issues. Personally I feel as if the Si could be strongly competitive, at least on the regional level. On a National level I think it could trophy, but would definitley more than likely fall well short of first place. Same boat that I'm in, FWD FTL. But it's still fun to try. And even more fun coming off course and people looking at you funny saying, "That was a Sentra?" ![]() Look forward to seeing you out there on the 6th...only two more weeks! |
#725 (permalink) |
Good call, didn't think about the SP* classes. Either way with your current mods your outgunned in both SP* and SM. But just take that TBS off and you'll have tons of fun in STX. Looks like we currently have 10 pre-registered for the season in STX (including the two of us) and can imagine having a couple more signing up as the event gets closer. Should be a good time, just look for me in paddock in the next couple of weeks, you can't miss me.
#730 (permalink) |
You're doing it wrong!!
Haha, hey man, you weren't there. You don't know what went down!
We totally convinced them to open it back up though.Infact, I have an email straight from the man himself and I quote... "[Gonzo], I re opened the season subscriptions for you. Here is a direct link to register." How's that for special? ![]() Sounds like you are going to make the first practice event? We need the rest of these NoVA, DC, MD slobs to join in on the fun. Oh I also got one of the 6 extra spots they opened for the Test and Tune. I'm totally pumped about it. 40 runs in a day! I could definitely use the experience.
#731 (permalink) |
Sounds like I'll be seeing for 3 weeks in a row then (4/6 Practice, 4/13 T&T, and 4/20 Points #1). I'm actually going to split my T&T day with Pat Griffith. I figure I really should only need about 20 runs to get everything setup and knock some of the rust off. I'll be testing out the new Koni/GC setup and the Stones, figuring out tire pressures for the new tires (ran 615's last year) and adjusting the Konis and the RSB to where they need to be to get the car balanced.
I can't wait...I've been thinking about this since the last event last year. |
#732 (permalink) |
Sounds good. Damn I forgot that was 3 weeks in a row. I guess I'll try to make them all, heh. Pretty intense start to the season.
What tires did you end up getting? I am leaning toward either RT-615's or Dunlop Sport Z1's (RE-01R's are a bit cost prohibitive since I need to pick up a set of el cheapo wheels to go with them) Plus right now I am still learning and having fun so I don't need super competitive tires. Last edited by Gonzo; 03-26-2008 at 11:06 AM. |
#733 (permalink) |
If you don't want to spend a ton of money, best bang for the buck would be the 615's. I think you can find 235/40/17's around $111 a piece, or so I've heard. I'm running 245/40/17 RE-01R's, but still need to get them mounted. Will be doing that this Tuesday along with an alignment since I just completed the suspension install. I just hope with the new wheel/tire setup I can still run -2.5 camber. If not, I may just have to get spacers, but we'll see on Tuesday.
#734 (permalink) |
I kind of wanted to get 245/40 since that is the max for STX but the 615's don't come in that. I guess even so it doesn't make too big a difference. Would the 615 still probably be a better choice than the Z1?
235/40-17 RT615's on 17x8's sounds good? Now I just need to find some wheels. Maybe I'll just get the cheapest thing on TireRack that isn't too heavy... I also need to go ahead and order my camber bolts and arms... |
#735 (permalink) |
Forget to mention the Z1, but I've heard they're going to be a bit pricey, hence why I didn't mention them. As in pricier than the Stones.
I ran 235/40/17 615's on 17x7.5 for the last two years. The 235 will fit better on the 8" wheel, so you'll be good there. As a relative beginner, there's not a huge benefit in going all out on parts in the beginning as there's a ton to learn in the mean time. And if you're trying to stay in a budget, the 235 615's will definitely help you out there. As far as camber goes, I saw you mention the arms. IIRC, you can't have adjustable control arms AND use camber adjustable suspension top mounts. Not sure if you have them, but just want to make you aware before doing any STX illegal mods. Double check the rulebook though. |
#736 (permalink) | ||
Ah, here it is. This is assuming that the Si front is a Macstrut, which I "think" it is.
![]() Quote:
#740 (permalink) |
Check out edgeracing.com, I had success with them a couple years back.
![]() Looks like they have them on sale for $111 each. Not shabby at all. Edge Racing - Tire Details Last edited by piknockout; 03-26-2008 at 03:28 PM. |
| CHECK YOUR CAR, if it gets towed! | Rommy | Garage | 15 | 05-10-2006 02:38 AM |
| Check your lug nuts!!!! | Chitown SI | Wheel And Tire Upgrades | 11 | 04-22-2006 03:32 PM |
| CHECK YOUR LUG NUTS!!! | Chitown SI | Civic SI | 1 | 04-20-2006 11:19 PM |
| check this out guys/girls | 2006SI | Autocross & Sanctioned Drag Racing | 9 | 04-12-2006 10:42 PM |
| Anyone got a carfax account? | Kabs | Water Cooler | 15 | 12-23-2005 12:02 AM |
