#583 (permalink) |
Whaaaaaaaaaaaaapsssh!!!!!
![]() Join Date: Feb 2007
Nick
Ok, so I've purchased this today as my new suspension upgrades. Will this put me in the DSP class or am I still STX...
Progress Rear Sway/Front Sway Eibach Pro-Kit SPC Front / Rear Camber Kits with the 5 strut braces I already have, I figure pairing this with a good set of tires will make my car turn quite comfortably on two wheels for those ridiculous hairpins. I am still researching what "Camber, Toe, Caster" have to do specifically with the way the car handles. Anyone want to give me the Layman's definitions?
[center] |
#584 (permalink) | |
Anthony "Mario" Crea NNJR-SCCA |
#585 (permalink) | |
Slow in. Fast out. There's no fast way around the typical autocross hairpin (one pivot cone correct?) 1. Stay about 2-3 car widths off the pivot cone on your approach (assuming they give you lateral room to work on this course) 2. Slow way down (10-15mph) as you work the car towards the apex. Stay in second so as to mitigate wheelspin and come off the corner hard on the throttle as you are unwinding the wheel. That last part is very important. The Si lacks enough low rpm torque that the LSD should help you guys. Try that next time you have a hairpin on a course. Anthony "Mario" Crea NNJR-SCCA |
#586 (permalink) |
Louder than 4 F404-GE-400
Also, that thicker front sway bar is going to lessen mid corner rotation and increase understeer coming out of the corner. Remember, the stiffer end slides first. If you are already pushing in the corners, why make the front of the car stiffer? Getting bigger front and rear sway bars isn't going to change the balance all that much because you are making both ends stiffer. If you want the rear to come around, make it stiffer than the front.
You know what the sun's all about when the light go out. |
#587 (permalink) |
Some of the braces are questionable and likely not legal (along with being completely unnecessary). The sways and springs are legal in both ST and SP, but the the camber kits are only ST legal (for example, the rear kit is absolutely NOT allowed in SP). Also, the ingalls stiffy is not legal in ST either.
#588 (permalink) | |||
Nick
To all.... Wow......... Can't I just show up and drive?!!?! ![]() ![]() Thanks Mario, that makes sense and I'm prettty goood at staying clam enough to do things that I'm told to try behind the wheel. I don'tt get excited enough to mess up. For now anyways. To the rest, since they're just stut braces, I didnt't realize that it would change my class. And I'll put the rear sway on first and see how it handles, then try the front sway. I do think the rear is what I want to come around and based on Sirbelch's theory, that should give me the turning thtat I want. Thanks all.
[center] |
#590 (permalink) | |
#591 (permalink) | |
i have seen people on offbrand tires (generals, federals, etc) do reasonably well. i wouldn't worry about it too much, just watch your tire pressure after every run |
#594 (permalink) |
yea ill be doing the dfw area scca and equipe rapide events this year. i am, by no means, a pro. i just started auto-xing my si last season. there is a novice driving school happening soon. i think on march 15, it's $60, and that includes the fee for racing the next day.
go here for more info Texas Region SCCA Solo2 Autocross |
#596 (permalink) |
Nick
Just ordered some new rubber!! 215/40ZR-18 BFGoodrich g-Force T/A KDW 2!!! Should be here today or tomorrow just in time for the event saturday. anyone wanna come with?
Solo Autocross In Orangeburg, SC this Saturday
[center] |
#598 (permalink) |
Nick
my last ones were wider tires. they didn't benefit IMO... Then again, they were proxes.
Here's what they look like. SuperView of the BFGoodrich g-Force T/A KDW 2 ![]()
[center] Last edited by nycclaye; 02-14-2008 at 06:19 PM. |
| CHECK YOUR CAR, if it gets towed! | Rommy | Garage | 15 | 05-10-2006 02:38 AM |
| Check your lug nuts!!!! | Chitown SI | Wheel And Tire Upgrades | 11 | 04-22-2006 03:32 PM |
| CHECK YOUR LUG NUTS!!! | Chitown SI | Civic SI | 1 | 04-20-2006 11:19 PM |
| check this out guys/girls | 2006SI | Autocross & Sanctioned Drag Racing | 9 | 04-12-2006 10:42 PM |
| Anyone got a carfax account? | Kabs | Water Cooler | 15 | |
