#21 (permalink) | |
In case you want to see how the Si is doing in other venues here are the results for the Jul 9th Solo in Council Bluffs, NE
http://www.nrscca.com/results/Solo060709.html I was pretty impressed with how well the car did (not my car). Seemed like this shorter auto-x cross may have favored this car some. Quote:
#22 (permalink) |
Thanks Janizary
I was in the novice class (I have alot to learn but am enjoying it) and will be in the novice class for atleast 1 more event. After that I am not sure of the class I will be in, I lowered the car so I am not sure what they will and will not allow here in my local area. shawn |
#25 (permalink) |
not an autocrosser..but wanna try one, but can't find a track... a nieghbor of mine owend a 1993 rx7 and 2 turbo miata.. and some guys drop by every friday and seen 2 red 2 silver 1 black 2 white 1 yellow rx-7's.. i talk to these guys and they autocross in VA..
#26 (permalink) | |
Have you registered? I think it closes Friday (7/14). E.T. Last edited by etf; 07-12-2006 at 10:41 AM. |
#27 (permalink) | |
#28 (permalink) |
that VA race track is the only one closer and theres a dragstrip in rockingham wich is an hour and a half from RTP... i can say that rockingham is one of the good race track in the US... theres always an event going on in there..like NOPI nationals just this past weekend..and here in NC theres a 11mile mountain pass called the tail of the dragon..
#29 (permalink) |
holysh*t, I'm moving down there and I totally forgot about tail of the dragon:)
Damn, so I have to drive almost two hours just to autocross? That is going to be a pain in the arse. I guess that is the only way. On a good note, VIR would not be that far from me and I know nasa and a lot of other clubs run events there all of the time:) |
#30 (permalink) | |
#33 (permalink) |
I've been Autoxing in Texas with San Antonio Sports Car Association and SPOKES ...
http://video.google.com/videoplay?do...10244298512153 But in August I'm moving to Boston, MA and trying to decide if I want to race with Northeast Region SCCA or drive down to CT to race with that club. These clubs don't offer Tire classing ... so I'm also trying to decide: 1. Stay in GS and save money by making no mods (I'll be in grad school) but be up against R-comps 2. Go to STX and make what minor mods I can afford (like replacing my slipping crash bolts with cam bolts, maybe a sway bar ... MAYBE trying to get a sponsorship). |
#35 (permalink) |
Autcrossing here in SJ CA kinda died down for awhile. Don't know why, but I'd love to get into it too. Anyways, the fools on the street aren't nearly as good as those who autocross. I wouldn't say i autocrossed before, but I have done similar stuff on authorized parking lots where cones were laid out too. I took my friend's EK4/9 (95-99) Civic for 2 laps. I didn't even pass 80mph cus it didn't have long straightaways, but I experienced more G's pulling on me. I want to try it out again, spoon'd b18c-r swap with tein coilovers and stripped to the bare chassis. he pulled 4 seconds faster than a turbo'd integra GSR and 1.2 sconds faster than a 350z. Damn, I'm hella hyped up again.
fun as hell. |
#36 (permalink) | |
Would you mind revealing how much camber you ended up getting after installing the bolts? I currently autox an 05 STi and may end up Running my Si next season. |
#37 (permalink) | |
*FACTORY CAMBER BOLTS: 04512-SNA-305 Approx. $6.00 each (require 4 altogether) These bolts yield no more than 1/2 degree. Frankly, there isn't much room between the strut housing and the top of the hub to allow anything silly with the OEM units. I am certain something from SPC would yield more, but they are illegal for Stock class SCCA autocrossing. Anthony "Mario" Crea |
#38 (permalink) | |
I'm seriously thinking about making a few minor changes (like "real" cam bolts, rather than "crash" bolts like this) and moving to STX. Of course - that opens the door for ALL kinds of mods that I really shouldn't be spending on while in grad school ... |
#39 (permalink) |
[quote=poopsi]I did this - and I'm disappointed with the results. While I did gain about .4 degrees of neg camber on each side ... I'm now dealing with possible positive camber on both sides.
QUOTE] I'm a bit lost here; you mentioned that you were able to get neg .4 degrees of camber as a result of switching to crash bolts. How in the world are you dealing with positive camber on both side? both side of what? did you not perform and alignment after the switch? You then talked about to STX because you want to switch to cam bolts that will yield greater negative camber, please help me understand your logic in doing this, since you will not change any other suspension component, and you are still wearing street tires. What I found during my first autocross with the car bone stock (no alignments), and wearing a set of khumo v710s, is that the car behave way better than I expected. In fact, I felt that there were more times left to be had with more seat time. As Anthony stated, when I was at Englishtown, the car would benefit with a little bit of toe out on all four corners. Furthermore, I found the SI to understeer a bit less than my EVOs and STIs that I've been autocrossing for the past two years. Awaiting your further explanation . . . . |
#40 (permalink) | |
I've been quite pleased with the Si's stock performance, especially on my Azenis - don't get me wrong. But going up against race tires in GS ... I just can't compete with that (and don't want race rubber). STX - no race tires are allowed, so I'd be on "even ground" in that respect. If I switched to STX ... I'd likely be considering some suspension work as well (which is a good reason to stay in GS - I'm starting grad school in the fall and need to watch the budget). It's really just an idea I'm throwing around, and I do appreciate your view on GS vs STX! As long as I'm autoxing ... :) And the cam bolts wouldn't really give me great camber ... but they wouldn't slip. Actually - if I could devise some kind of shim to slip in with my crash bolts, perhaps that could prevent some of the slippage. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
