#203 (permalink) |
Driver: Randall Harris
Class: We'll see... probably GS Car: Civic Si Sedan Mods: None yet or planned. This car is my daily driver. I want to run it a few times before I even think of modifying it. On second thought...the brake pads, rotors and fluid will be changed prior to my first track day, which will probably be in May... I have been auto-x'ing since 1988. In that time I have run Miatas (rented from Hertz...), a host of BMW's, a 2005 Mini Cooper S and a 1989 MR2 Supercharged (this was a full track car). I have won many 1st in Class in BMW CCA events. At my last event I took 2nd out of 19 cars in the stock 6, 8 and 12 cylinder class of BMW CCA while driving a totally stock (down to the AS tires) BMW X3 (yes...the SUV). I think this Civic is going to be a bunch of fun to auto-x and I can't wait to get it to the track!!! |
#205 (permalink) | |
I'll be at the Curve too, finally sent an email to Greg. I don't think the M will be ready for the season yet, so I may putz around in the Civic. |
#208 (permalink) | |
I never mentioned this in the PM's, but at my first ever autocross way back in 1994 I ran my 1993 Civic on the stock 13 x 5" wheels with the OEM 175/70/13 Goodyear Invicta's... I learned a lot about smoothness regarding steering inputs and braking and throttle modulation very quickly with those tires. This is why I suggested this to you. Anthony "Mario" Crea NNJR-SCCA |
#211 (permalink) |
Driver: Jeff Jacobs
Car: 2006 Civic Si - White Class: G-Stock Mods: Crash/Camber bolts. Auto-x alignment. K&N Filter. Magnacor Wires. Smaller Civic front bar. Hoosier A6 and Kumho 710s on Fliks and Enkeis. Autocrossing since 1990. Started in a `90 Integra. Also have run Neons, a `99 Miata, and most recently Mini Cooper and Cooper S. Have been doing SCCA ProSolo and National Tours and Nationals since 1995. Posted a video of my first event in the Si on YouTube: http://www.youtube.com/watch?v=nM755wUDC4A |
#212 (permalink) |
Welcome Jeff!
For all you noobs, that video shows how us men really autocross. :) So Jeff, have you fully defected from the MINI camp or are you still running Chiles' base MINI or your own Cooper S Nationally? Just so you know, Koni anticipates something by summer. Anthony "Mario" Crea NNJR-SCCA |
#213 (permalink) | |
That was a decent run, but you have to overlook the left-hand turn after the long slalom series where I got in too deep, too hot. It's just so hard to take your foot off that gas pedal cause it makes the cool sounds stop. Yes, the delay in anybody having adjustable shocks for these things is disappointing. If I were campaigning the Si seriously this year, I'd go ahead and spend the money to have custom double adjustable inserts made, but for now my plan is to keep running the 05 Cooper S at national level events and bum rides in new turbo Cooper S's when possible (spirited test drives so far seem to show a lot more low-end, which is good for autox). Then, we'll see how G-Stock looks for 2008 IF the new Cooper S is so fast it gets them all moved to D. In my opinion, owning and autoxing both, the autocross problems with the Si are that when you are not in V-tec it's an H-Stock car, that 2nd gear runs out too soon for most national-level solo courses, and the straight-line speed advantage is outwieighed by the Cooper S size advantage. The analysis might be different for road racing. Jeff J. |
#217 (permalink) |
That why in most pictures you see of auto cross, there are no plates on the car, or they are blurred out or they re covered with blue tape. Also don't know if all regions with SCCA allow you to do this, but when I enter my car, its a Silver Bullet not a Honda Civic Si. As long as you are in the right class I don't think any one would care what your car is called. Reason being for me is the dealers watch the papers here since the results are printed and have been knows to deny warranty work because of what they saw in the paper.
#218 (permalink) |
My first event is this Sunday. The suspension/wheels/tires are completely stock. I'd like to keep it that way until my 4th or 5th event. My question is in regards to tire pressure, I heard that I should add an extra 5psi before the event. But I'd like to make sure... can someone please tell me how many psi I should put in the front and rear tires? They are the stock Michelins (all season tires). I know they don't have grip at all, but I'm still going to run with these for the first couple events.
BTW i have a 07 si coupe |
#219 (permalink) |
Another question is related to helmets. I saw some motorcycle helmets made by HJC and KBC that are Snell M2005. Can someone please verified whether I can use those at SCCA events... or do I have to get one that is SA2005? I think M=motorcycle and SA=special application.
| CHECK YOUR CAR, if it gets towed! | Rommy | Garage | 15 | 05-10-2006 02:38 AM |
| Check your lug nuts!!!! | ||||
