Old 04-14-2006, 09:58 AM   #1 (permalink)
Ep3racer954's Avatar
FG*SQUAD #87
my moroso e/t's
well i went to moroso wednesday night and got a couple runs in...
my best was a 15.2... i could not get traction... ok well i think launching at 4k is out of the question now... it was 72 degrees and i had 3/4 tank of gas with no weight reduction and on stock tire pressure....
Plans for next time: have little amount of gas, remove spare tire and jack, lower tire pressure and launch at a lower RPM... any other suggestions?
Ep3racer954 is offline
Old 04-14-2006, 10:04 AM   #2 (permalink)
Crazy Yellow Puppet
CameronJr9's Avatar
Back and Forth Forever
You said you are running with stock tire pressure. Are you running with stock tires? That might be part of the problem with launching.
CameronJr9 is online now
Old 04-15-2006, 08:02 AM   #3 (permalink)
Im assuming you have a donut for a spare.
does removing 10 lbs total really make that much of a diff?
TypesFanatik is offline
Old 04-15-2006, 08:06 AM   #4 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
every little bit of wheit savings helps. A rule of thumb is that loosing 100lbs will imprvoe your quater time by .1 second. So loosing all of you crap in the trunk, and running as little gas as nessecary could produce a slightly lower time. But the best way to get the time down is practice, people have been getting into the high 14s on those stock tires. The more you practice the better you will get. Also as Cam said a tire uprade with greatly improve your holeshot which in turn will also give you a lower time. One last thing, if you don't care about tire wear, lowering your psi in the front tires (ONLY FOR THE TRACK NOT ON THT ROADS!!) Wills lightly improve your grip so you may not spin as much. good luck and be sure to post up some times next time you go out!
Originally Posted by Gonzo View Post
if I found out I was pregnant at 16 I think I'd be flipping the *#&% out.
jed = hermaphrodite
twistedframe is offline
NHRA @ MOROSO WHOS GOING?? 2RotorMotor South 3 04-02-2006 12:44 PM
White si at Moroso 2RotorMotor Autocross & Sanctioned Drag Racing 0 03-27-2006 02:37 PM
Moroso Test and Tune March 24th 954K20_SI South 3 03-24-2006 09:26 AM
Moroso Test and Tune March 17th 954K20_SI South 4 03-17-2006 09:34 AM
