#43 (permalink) | |
230 WHP TURBO SI WILL RUN 13.6 TO 14.3 ALLDAY BOTH CAR WITH SLICKS |
#44 (permalink) |
I have the Greddy kit but have issues when I hit the VTEC with E-Management. My boost until I hit the VTEC stays stead @8lbs but looses between 2-2.5 of boost. I keep my foot on the throttle 100% between shifts but can't make up the power lose. I have DOT drag radials and my last run was given a tip from a local to start in 2nd gear, hold the brake and turn the wheels to get proper heat and that worked great. Extreme in MD installed the kit and I've had the car tuned by Extreme and SRT technologies and both shops where having issues with tuning. Apparently the E-Management is only good for fuel injector tuning and according to Greddy the VTEC and ignition are future for the K20Z3 and will release another product in the upcoming months. Soooo, that left me a decision on having 2 different piggy back systems to control fuel, VTEC and ignition. Hondata is rumored to have the K-Pro coming out early next year but I'm too impatient so I decided to go with a Haltech E8, larger injectors, larger turbo, Pauter 9.0-1 comp rods, CP pistons, walbro Fuel pump, and exedy stage 2 clutch. This will give me lower compression, aftermarket ECU that controls injectors, ignition and VTEC and a motor that can handle 500+whp. I should be pushing 11's - 12's and the biggest issue will be traction.
I have spent quite a few dollars and seem willing to spend more to help support the CIVIC cause. Most of my friends have EVO 8's and 9's and consistently remind me that I've already spent the difference between a EVO and SI. As for other out there that have SI that are hitting 13's without boost.. congrats!! |
#47 (permalink) | |
That claim that a N/A car will be faster that the same one with a F/I setup with the same top end power. That is not always true. Remember that F/I can produce vast amounts of power in the mid and low end too.
#49 (permalink) |
all of you guys that are knockin this guy are a bunch of idiots...this guy is excited that he broke into the 13's and all ya'll can say is...
you should be going faster... i could do better.... i did better n/a... so what....he is happy about his car and wanted to share his happiness..i'm glad i don't have an Si..if i did and i modded it i wouldn't share my success with ya'll 07civicMD- congrats on your car hitting 13's...thats cool..best of luck on your way to quicker times |
#50 (permalink) |
so were u get this from reading other people's post or personal experience?,,i just happened to have similar car one allmotor and one turbo , base on the track time and dyno my allmotor car ran faster than my turbo car..example a car that weights 2000 lbs with 300 whp allmotor will run high 10's lo 11's, a 300whp turbo car with the same weight will run mid to low 12's ?????????
#51 (permalink) | |
*The turbo suffer from a lot of LAG *Torque curve is very poor |
#54 (permalink) | |
#56 (permalink) | ||
As for turbos, power is power. 230whp @ 7800rpm is still ~155ft-lbs no matter where the work comes from. The disadvantage you're going to have with a turbo will obviously be lag, and the abundance of low-end torque on a FWD car which will cause serious traction issues. Claiming 200whp N/A is faster than 200whp turbo'd just isn't a correct generalization. For all we know extra torque in 1st gear or throughout other areas in the powerband can help makeup for the lag. A turbo'd SI is nearly guaranteed to have higher peak torque than N/A even if the HP is exactly the same. The two cars of course would have to have very different torque curves. Last edited by skiddy; 10-03-2007 at 12:40 AM. |
#58 (permalink) | |
#60 (permalink) | |
I'M CONFUSED SO IF I HAVE I/H/E AND IM RUNING 14.5-14.6 IN 1/4 MILE I DON'T NEED A REFLASH TO RUN 13.9-13.8??? Last edited by slow4drsi; 10-03-2007 at 10:56 AM. |
LinkBack to this Thread: http://www.8thcivic.com/forums/autocross-sanctioned-drag-racing/58965-finally-13s-my-si.html
| GTI vs. 2007 Turbo SI - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com | This thread | Refback | 02-12-2008 03:31 AM | |
| Finally installed my IVA-D310 (pics) | ImTheVoiceOfGod | Introduction & Pictures | 15 | 06-07-2007 06:53 AM |
| Finally took some pictures of my FBP FA5 | notacop | Civic SI | 15 | 06-04-2007 03:29 PM |
| 13s? | losboyfg6 | Autocross & Sanctioned Drag Racing | 83 | 01-22-2007 05:55 PM |
| Finally (test) drove an Si today | dcfife | Driving Experience | 28 | 11-14-2006 12:26 AM |
