#3 (permalink) | |
Rene....
practice is your friend. |
#7 (permalink) | |
Then line up, put the car in first gear, depress the clutch and hold it down there while at the same time you're holding down on the gas pedal a little so that the engine is reving around 3500 rpm, hold it at that rpm and when the light turns green drop the clutch and continue by flooring the gas pedal. While you are droping the clutch and slamming down on the gas pedal you will feel and hear what kind of traction you are getting. So you might have pretty descent traction and simply dump the clutch or you might feather it. Hope this helps. |
#9 (permalink) | |
#10 (permalink) | |
Rene....
#11 (permalink) | |
#12 (permalink) | |
Rene....
When you racing at the track with street tires do you go in the water box and then do a burn out then stage, or do you go around the water box with no burn out then stage?? |
#13 (permalink) | |
#17 (permalink) |
Okay i'll answer your question real quick, launch your car at about 4500 to 5500, once you pop the clutch DON'T slam the gas just play with it untill you grab in between 5500 to 7000rpms that way you can win your launch and perhaps the race if you shift right. you have lsd so that will help alot. just let your tires grab in first gear and you might beat him. DON'T spin out all of 1st to 2nd gear
#19 (permalink) | |
Then I read the last sentence... Damn launch like that, I'd think you are afraid for your life, like somone is trying to kill you and you are going all out. I find I have better traction when I launch between 3000 and 4000 rpm. Above that is too much, unless maybe you drive an Si. that can rev up to like 8000rpms.
#20 (permalink) | |
| Shuttle launch | ajrich | Water Cooler | 2 | 12-11-2006 06:27 PM |
| launch | 06blkstealthsi | Autocross & Sanctioned Drag Racing | 10 | 09-25-2006 10:45 PM |
| Toyota mega launch | CHRIS | Water Cooler | 12 | 05-05-2006 09:23 AM |
| best RPM for launch and shift | el_ben2 | Autocross & Sanctioned Drag Racing | 2 | 04-20-2006 10:39 PM |
| Honda Civic Si Launch Night on Speed Channel | jasonandre | Civic SI | 14 | 03-11-2006 06:16 PM |
