Old 03-11-2007, 05:18 PM   #1 (permalink)
SacrificeTheory's Avatar
Chris
My First Time at the Track
I went to Englishtown for the first time today. My times kind of sucked, but I suppose it takes practice.
My Performance Mods:
Greddy Evo2
Injen Short Ram Intake
First Run
R/T - .791
60' - 2.423
330 - 6.610
1/8 - 10.029
MPH - 72.50
1000 - 12.948
1/4 - 15.420
MPH - 91.73
Second Run
R/T - .760
60' - 2.588
330 - 6.807
1/8 - 10.208
MPH - 73.92
1000 - 13.102
1/4 - 15.531
MPH - 93.29
My first run I launch at 3000/500rpm. The second run I launched around 2500rpm. First run was without VSA, second was with VSA.
Any tips?
SacrificeTheory is online now   Reply With Quote
Old 03-11-2007, 05:24 PM   #2 (permalink)
John
React Faster..........
xxmstajxx is offline   Reply With Quote
Old 03-11-2007, 05:25 PM   #3 (permalink)
John
Go on 2nd yellow......
Old 03-11-2007, 05:25 PM   #4 (permalink)
Rems07si's Avatar
Remy
Rems07si is offline   Reply With Quote
Old 03-11-2007, 05:29 PM   #5 (permalink)
qwerty :)'s Avatar
kyle
power shift
qwerty :) is offline   Reply With Quote
Old 03-11-2007, 05:31 PM   #6 (permalink)
fuller083's Avatar
R/T has nothing to do with E/T and Trap speed..... Work on your launch point and your shift points, and like qwerty said... POWERSHIFT!!!!
fuller083 is offline   Reply With Quote
Old 03-11-2007, 05:33 PM   #7 (permalink)
Coop's Avatar
Coop
what rpm was you shifting gears at?
Coop is offline   Reply With Quote
Old 03-11-2007, 05:34 PM   #8 (permalink)
Chris
I was redlining every gear.
This is also my first manual, so I guess that doesn't help.
Old 03-11-2007, 05:37 PM   #9 (permalink)
fuller083's Avatar
It takes time man... You can't expect to go out to the track for the first time and hit those low to mid 14's. The best advice I ever got for drag racing is this... Drive your car more, and get as much seat time at the track as possible. It takes practice and eventually you'll be hitting those numbers I mentioned above..
Old 03-11-2007, 05:42 PM   #10 (permalink)
brooklynscat69's Avatar
I was there last weekend. Saw a couple of SI's but none from this site.
brooklynscat69 is offline   Reply With Quote
Old 03-11-2007, 06:18 PM   #11 (permalink)
Chris
Like I said, I'm new to the manual world. How exactly do I powershift?
Old 03-11-2007, 06:30 PM   #12 (permalink)
Acorns!
webby's Avatar
what they mean is not taking your foot off the gas between shifting. So even as you put your clutch in and throw it into the next gear, you keep your foot on the gas. It's not exactly the best thing for the car, but you will get quicker times.
webby is offline   Reply With Quote
Old 03-11-2007, 06:33 PM   #13 (permalink)
qwerty :)'s Avatar
kyle
and only do that if you can shift fast.. dont leave your foot on the gas and shift normal.. i basically slam it into gear
Old 03-11-2007, 06:36 PM   #14 (permalink)
SIcBoy's Avatar
jr
takes practice cuz you can miss sometimes and you'll get a worse time
but with practice, 15 even with out a doubt. good luck
SIcBoy is offline   Reply With Quote
Old 03-11-2007, 07:42 PM   #15 (permalink)
The main thing is to have fun.
Drag racing is a blast and very addicting. These guys have giving you great advice,to drive your car as much as you can and get lots of practice. Try and get your shifting faster before you start power shifting. It takes a little time to get the hang of it. Also your 60 foot times are real slow. Meaning your either riding the clutch off the line,or the tires are spinning bad. Either way pay more attention when you leave the line doesn't matter at what RPM works best for. All that matters is the ET is lower at the end.
But mostly relax and have fun the rest will come with time.
SI4US is offline   Reply With Quote
Old 03-12-2007, 04:36 AM   #16 (permalink)
projectprelude's Avatar
Aaron
ouch...with ur mods you should even be seeing 15's...i ran a 15.6 with my r18...but i do understand its ur first time, practice makes perfect!
projectprelude is offline   Reply With Quote
Old 03-12-2007, 11:14 PM   #17 (permalink)
bboylocob's Avatar
BRENT
at the track try launching at about 4000rpm.you will spin through most of first but when it catches you will be in vtec.on the streets launch at about 3000-3500rpm cuz the streets have more crap on the road which makes you spin at lower rpm.it takes practice to get it down.
also about the powershifting the best advise someone can give you on how to learn it is:
1)practice at about 6000rpm so you wont redline it if you miss.and as you get better shift higher
2)when powershifting your supose to keep your foot down on the gas when shifting but i feel it is better let your foot off just a lil and i say that because then if you miss shift it will be less likely that you will be bouncing off the rev limiter.
bboylocob is offline   Reply With Quote
Old 03-12-2007, 11:52 PM   #18 (permalink)
just practice some more you should be able to get mid 14's atleastttttt...POWERSHIFT lol
R3DL1NETHIZ23 is offline   Reply With Quote
Old 07-18-2007, 11:59 PM   #19 (permalink)
RANGERSi07's Avatar
yea powershift...I just got back and I couldn't hook at all. My best was a 15.1 with a R/T of like 1.2 I know I suck no traction at all.
RANGERSi07 is offline   Reply With Quote
Old 07-19-2007, 02:41 AM   #20 (permalink)
adamhoud's Avatar
Adam
You can't really count 5hp worth of mods to help out at the track, learning to drive better will get you a much better time.
adamhoud is offline   Reply With Quote
New Track Day group to the site AZ Seat-Time West 5 03-02-2007 10:43 AM
Want to track my stock Si, what mods/advice i need my fellow track junkies? AznSupastar Autocross & Sanctioned Drag Racing 16 12-24-2006 04:08 PM
Track Day Werkt06Si South 0 11-02-2006 12:08 PM
John Legend - Once Again review w/ snippets NightKidsGTR Movies & Music Reviews 4 10-14-2006 11:36 AM
