Dave
AutoX Advice...
So a couple months ago I had my first autox. It was really fun, placed 17th out of 37, and 3rd in class (lost to 2 highly modded s2k's).
Now there are a couple things that I had issues with. First, I kept my VSA on since I am not 100% used to how the car handles with it off. I dont think that i like it on, it cut too much power to the engine when I needed it, but I still had terrible understeer in the tight corners. I think I could do better with the VSA off, feathering the throttle to help control the understeer. What do you guys do? Advice and techniques? Next, I know I had the wrong tires for this, Goodyear Eagle GT's. They were terrible, and since they were at 32psi there was tire wear all the way to the letters. So I should use a higher psi for all seasons? Correct? Lastly, since Ive had an autocross and now am trying to get ready for the next one, is there anything in particular that you guys do to help improve your times, besides seat time? Any advanced techniques, ect.? I can post the video of my fastest time if you want. Constructive criticism is always the best! Thanks! |
Definitely turn VSA off for auto-x. It will work against you to prevent the car rotating and give you understeer instead. It also makes it harder to learn the limits of the car.
PSI: too much and the tires lose grip. Too little and they will roll over onto the shoulder too much. Other techniques: Get there early and walk the course. Try to look ahead as you do this and record the apex and exit cones in your mind. After a run, think about what you would like to improve, then close your eyes and drive the course in your mind, building in those improvements. This is not easy. For the first two runs, if you can simply imagine your way around the course you are doing well. Be smooth - think about the elasticity of the tires. Elastic bands snap if you pull them quickly (tires skid if you jerk them), but stretch out further than you would expect if you slowly pull on them (tires grip more if you load them up gradually) Finally, carry more speed into the corners, use trail braking (or even just lift off throttle braking) and a later apex to avoid too much power-on understeer on the exit. A little understeer on the way in is OK as long as you make the correct apex. Too much and a missed apex means you came in too fast, or trail braked too much. |
Dave
Thanks for the advice dragon.
Slammed em1, my mods at the time of the autox was just injen cai and hybrid cable bushings. Currently I have injen cai, flashpro, hybrid full short shifter and hybrid bushings. |
Chris
I'm looking to start autocrossing next season. My dad used to autocross his porsche 912 back in the day, he managed to find this ( SCCAForums.com - SCCA Racing Discussions > Programs > Autocross > Autocross Handbook) read through it and it gave me a much better idea of what i should try to do. hope it helps
| Need Clutch Advice Thinking Stage 4 (supercharge advice) | 07REGSI | Clutch & Transmission | 13 | 05-18-2011 09:26 PM |
| First AutoX on Sunday.. Advice? | Winkler2009 | Autocross & Sanctioned Drag Racing | 4 | 04-14-2011 12:01 PM |
| Advice on dedicated autox wheels | Brett_C | Wheel And Tire Upgrades | 19 | 01-05-2011 10:17 PM |
| Atl autox? | orbhot | Autocross & Sanctioned Drag Racing | 2 | 01-15-2009 12:35 PM |
| what to get for autox??? | stare_decisis | Suspension and Brakes | 107 | 09-26-2007 05:31 PM |
