#41 (permalink) |
OP: Nice idea for this thread!
I'm relearning how my car behaves with the Koni/Neuspeed sport combo, and BC lower balls. And if I'm really lucky, a used set of Motegi Traklites will pass my inspection this week that I found at a stupid low price (better not be cracked!) and I'll be wrapping my Star Specs around them instead of the stockies. EVO driving school for sure this spring to test the limits, and always happy to embarrass myself knocking over cones! |
#42 (permalink) | |
#43 (permalink) | |
Alex
Does anybody know if 16" rims will clear our stock brakes? I'm thinking about a set of stock regular civic wheels for track wheels? If those don't worry I'll just but another set of stockers. Sent from my Autoguide iPhone app |
#44 (permalink) |
OEM size tires, 215/45/17. I'm not sure about the wheel offset, since I bought them used. They were originally purchased from Tire Rack, and their website sells a 17x7 with either 42 or 50mm offset. I'm guessing mine are the 42mm version. You will need hubcentric rings if you run these wheels.
#45 (permalink) | |
Although, now that I think about it... If you do your brake swap more than 6 months before taking your car to the track, just use OEM fluid. Some organizations (BMWCCA comes to mind) require you to have your brake fluid changed within 6 months of your track day. No sense wasting the good stuff. |
#46 (permalink) |
JLee
Cars: 2007 Civic Si Sedan (DD & track) Car spec: Engine: Injen CAI / KRRH / Invidia Q300 / Flashpro + tune / Magnaflow HFC Suspension: GO Pwr Coilovers (8k/10k) Ingalls F&R camber kit Progress RSB Brakes: TL-S Brembo TL-S rotor (centric blank) Stoptech Street (DD) , Carbotech XP-12 (Track) Hawk HP+ (rears) Goodridge SS lines Motul RBF600 Custom Brake Ducting Wheels: 17x9+35 (255 Hankook RS3) Fronts 17x8+35 (225 Hankook RS3) Rear Future mods: Oil cooler (in process) Kaaz 1.5 LSD Type R Final Drive Gear Set Clutch & Flywheel Set Where you would find me: Buttonwillow, Willow Springs, Socal tracks Last edited by cambodianricer; 02-20-2012 at 01:07 AM. |
#47 (permalink) | |
Yetti 000
Some can make the argument for and against the extended ball joints. I only mentioned them purely as an interest item down the road. Far too early to tell if I will even notice a slop in turning once I move forward with the Tein setup. I'm only trying to change what I can tell is holding me back, not building a track car that i have to learn to drive. |
#48 (permalink) | |
JLee
Didn't know we can fit a +55 in the rear!
#50 (permalink) | |
Yetti 000
#52 (permalink) | |||||
Bow chika bow wow
#54 (permalink) | |
Matt
I'm in the process of designing a brake ducting system for my FG2, would you mind explaining how you did yours? |
#55 (permalink) |
Bow chika bow wow
I went through the fog light housings, over my CAI(for driver side), tied it to the strut, and curled it onto the spindle(?) facing the caliper. Same for passenger side except substitute the CAI for a removed windshield washer fluid reservoir. I didn't want to remove the reservoir but combined with my dual heat exchanger oil cooler and Aftercooler lines there just wasn't any room.
#56 (permalink) | |
Thanks much! |
#57 (permalink) | |||
Anthony
******Has anyone here taken off the dustshields? I mean they only restrict heat from leaving the brake assembly. Last edited by BlackFA522; 02-20-2012 at 12:00 PM. |
#58 (permalink) |
Instead of running brake duct hoses through the car by removing ww reservoir (which I gave up on, although you can find smaller reservoirs...), etc., how about either:
1. NACA ducts from hood, run the hose through the inner fender behind the strut towers. This could actually work, and you can buy a track day only hood (junk yard) for like $80. There's a fair amount of room to route the duct down behind the strut towers (2" diameter hoses) but you have to hole-cut the inner fender. Only about two bends in the airlow. 2. Or, install a track day only front lip (4") with duct hose inlet in the lip, and run the hose under the car. Don't think this would stand up to DD, but only 1 bend in the airflow, and highest pressure air intake zone instead of NACA ducts on the hood. I'm working on Option #2 right now, starting with the Club RSX garden liner front lip design! I'll post something if I can get it to work - still playing with intake nozzles for the mounting to the lip.
#59 (permalink) |
Bow chika bow wow
Blackfa522,
Before I had ducting I removed the dust sheds in hopes of better cooling. This helps, but depending on how hard the track is on brakes and how hot they get, the ball joints in the arms can get overheated since they're only an inch or so away from the inside of the rotor. I'd find a way to keep the dust shield or otherwise insulate the ball joints. Gold foil? |
#60 (permalink) | ||
Anthony
Or, you could just not have the duct in any kind of housing, as long as its sturdily mounted to the bottom of the car. Quote:
| Sailun Tires Track Date Official Event Thread (May 31, 2011) | GiveMeFreeStuff | Ontario | 68 | 06-08-2011 02:35 PM |
| anyone doing regular track hpde events with the supercharger stage 2? | racekar | Supercharging | 5 | 12-17-2009 10:02 AM |
| HPDE - Monticello Motor Club, Full Track, 7/31 | RR-Si08 | North-East | 0 | 07-23-2009 10:23 AM |
| Summer Track Meet: Official Thread... | Civicn33b | Georgia | 42 | 05-04-2008 04:30 AM |
