New Rules for 2012 *GS can have a rear sway bar*
Didn't see this posted here yet, but in my regional forums someone posted a link to the new rules for 2012.
http://scca.cdn.racersites.com/prod/...ck-dec-bod.pdf The Main thing for us: (Page 6) ITEM 10) Change 13.7: “13.7 ANTI-ROLL (SWAY) BARS A. Substitution, addition, or removal of a single anti-roll bar and supporting hardware (brackets, end links, bushings, etc.) is permitted. B. Substitution, addition, or removal of an anti-roll bar may serve no other purpose than that of an anti-roll bar. C. The use of any bushing material is permitted. A bushing may be implemented as a bearing. D. No modification to the body, frame, or other components to accommodate anti-roll bar addition or substitution is allowed except for the drilling of holes for mounting bolts. Non-standard lateral members which connect between the brackets for the bar are not permitted. There is also mention of a change to the use of Camber Bolts: ITEM 11) - Change 13.8.E: “If offered by the manufacturer for a particular model and year, the use of shims, special bolts, removal of material to enlarge mounting holes, and similar methods are allowed and the resulting alignment settings are permitted even if outside the normal specification or range of specifications recommended by the manufacturer. If enlarging mounting holes is specifically authorized but no material removal limits are specified, material removal is restricted to the amount necessary to achieve the maximum factory alignment specification.” So if i understand this correctly if Honda allows some material to be removed to achieve more camber than we maybe able to pull slightly more with the stock Crash Bolts? Discuss... |
Some manufacturers mention removing material to gain camber, but Honda does not. The only camber you'll get in Stock class will be less than 1 degree from the OE crash bolts. This new SCCA rule may as well have been called the Hyundai Genesis rule - they will be able to get more camber from the 'off-road use only' bolts that were illegal until the rule change.
![]() Join Date: Nov 2005
2012 Solo Rules - DRAFT posted!
So, rules parsers. A. Substitution, addition, or removal of a single anti-roll bar and supporting hardware (brackets, end links, bushings, etc.) is permitted. ---> Substitution, addition or removal of a single anti-roll bar is permitted. Substitution, addition, or removal of supporting hardware (brackets, end links, bushings, etc.) is permitted. So, it could be argued (I would not) that you can replace the rear sway bar AND end links and bushings front and rear. -mr. bill |
I think it's clear you CANNOT change both bars (my opinion as a former SCCA committee chair), but the opinion that matters is the SEB, so I'd encourage you to either visit the SCCAForums.com, there's 10 pages of comments about the new rule or write the SEB directly (seb@scca.org).
I bet in the forum discussion, there's definitive feedback provided on what you can and cannot do. |
btw-is anyone aware of a bigger RSB than 25.4 mm (1 in.)?
I see HPD has one for the Si. http://racing.honda.com/hpd/parts/pa...52300-F23S-A01 |
It's completely unambigous that you can only change ONE bar.
But it's ambiguous if you can change brackets, endlinks, bushings etc for only that one bar. Sorry, just a tech writer geek giving folks a hard time. The ambiguity would be removed with a simple addition, "...and its...." -mr. bill |
#10 (permalink) | |
Anthony
#11 (permalink) |
You can't buy the Honda Racing Line parts for the street. And you shouldn't run them on the street.
I'm ordering the Progress Rear Sway bar. (Update - Progress unobtanium, went with adjustable Whiteline.) (It is ironic that the racing part is cheaper than streets part though.) -mr. bill Last edited by mrbill; 04-10-2012 at 09:28 AM. |
#12 (permalink) |
Anthony
I wouldnt have bought it anyways. Thats a little too much of stiffness increase for me I think. Also, it would break the stock endlinks very easily, whereas the progress is okay with just the strengthening brackets.
I'm about to order soon as well, i think. I have been considering the tsx brake swap for the track but then again that will put me out of stock class autox... hard decision. Also, konis are now 20% off so i might go for those, an rsb, crash bolts, and a good alignment HFP suspension is cheap now too, too many options! I looked into it a little more a few months back when I saw that link. You can buy those parts, as long as you register and post your results from your last races (autox would work). http://racing.honda.com/hpd/race-for...quirements.pdf They have brake lines, engine mounts, upper control arm bushings F/R, front sway bar bushings, camber and caster plates for konis, brake pads, and an LSD. Last edited by BlackFA522; 03-04-2012 at 10:01 PM. |
| eibach rear sway or progress rear sway? | k20powered | Suspension and Brakes | 5 | 01-05-2010 07:05 PM |
| Ex with HFP and Si rear sway: upgrade rear sway with? | ryker | Suspension and Brakes | 1 | 07-31-2009 12:51 AM |
| People with experience with BE rear sway and Progress Rear sway | TdotSi | Ontario | 8 | 05-11-2008 04:09 PM |
| Progress rear sway and LX front sway installed | RWatters | Suspension and Brakes | 1 | 05-17-2007 07:41 PM |
