close to 13s. need pointers. - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Autocross & Sanctioned Drag Racing
Old 12-29-2011, 02:15 AM   #1 (permalink)
230whp Club!
Went to the track tonight and got two passes and the second run i was wheel hopping so bad i thought my engine was gonna jump out. ive been driving stick for 2 months and this is my 7th time ever launching a car.
MODS:
Injen CAI
Greddy EVO2 (60mm)
Skunk2 alpha header
Hasport 70a rear mount
hondata (running a basemap)
tein springs
no spare tire
rev limit: 8400
launch: 3000
street tires: 27psi
had 5 bars of fuel
i have terrible wheel hop. how much difference will boomba solid motor mounts make? what tire pressure should i run? and will a 70mm exhaust/pullies and tune really make a difference in my time?
really trying to hit a 13.8 or 13.9
HITvPASTu is offline
Old 12-29-2011, 02:34 AM   #2 (permalink)
K20Z3allmotor's Avatar
12.423 @ 109 mph No AC jaja
you need a tune. pulleys do nothing.
K20Z3allmotor is offline   Reply With Quote
Old 12-29-2011, 02:56 AM   #3 (permalink)
230whp Club!
first i need to get motor mounts i think because i cant launch without horrible wheel hop then ill get a tune. but should i get a 70mm or 3" exhaust? will it be a noticeable difference from my 60mm?
HITvPASTu is offline   Reply With Quote
Old 12-29-2011, 03:20 AM   #4 (permalink)
08slvrsi's Avatar
get an etd, it worked wonders for my wheel hop
08slvrsi is offline   Reply With Quote
Old 12-29-2011, 04:01 AM   #5 (permalink)
Rockawearbadboy's Avatar
David
3" exhaust and a tune.
-David-
Originally Posted by Rockawearbadboy View Post
Lmao youve been complaining about tires since like November....THAT'S 4 MONTHS AGO.
Originally Posted by austin1636 View Post
Lmfao I know... I could have got them but got retros lol
Originally Posted by BreeSi View Post
At least you will be able to see what you slamming into at night.
Rockawearbadboy is offline   Reply With Quote
Old 12-29-2011, 05:04 AM   #6 (permalink)
12.81@113 jrsc'd street tires
def a tune, and POWERSHIFT. launch higher
i had sri/h/e/pullies/tune/street tires/ss/omni cmc.
ran 14.13
stallion07 is offline   Reply With Quote
Old 12-29-2011, 10:40 AM   #7 (permalink)
230whp Club!
forgot to mention i have a em1 cmc. and i know the 3" and 70mm exhausts make more power up top but loose a little torque down low. to improve my 1/4 time do i need torque or top end is what im trying figure out...
couldnt launch higher. i was wheel hopping so bad im surprised i didnt break anything at 3k rpm
Old 12-29-2011, 11:07 AM   #8 (permalink)
killin's Avatar
Special.K
deff launch higher and slip the **** out of the clutch and powershift. and yeah get motor mounts
killin is offline   Reply With Quote
Old 12-29-2011, 04:36 PM   #9 (permalink)
08Sivic's Avatar
13.03@114 SC'd w/ Street Tires
Launching @ higher rpm will give more spin instead of wheel hop and on street tires that is what you want. Instead of slipping your clutch and ruining that, try feathering the throttle until you gain traction. With bolt ons and a tweaked base map tune I ran 13.9 @ 102mph. Launched between 4000-4500rpm and no power shifting. Your 2.2 60' looks good, you may be able to pull a 2.1, which will equate to 0.200 off your time and put you at a 14.0. So that being said, I would look for a little more power up top to carry you through the finish.
Since you're all motor, personally I would go 70mm to not take away so much torque down low, but give you a nice mid and high rpm range gain. Boomba mounts are nice, but wont take away all wheel hop at the track. It eliminates it on the street, but usually not at the track. Tune helps out so much with drivability and may give you a few extra hp's as well. These 3 things alone wont shoot you down into the 13's, but with more practice and a good launch you can definitely meet your goal.
Some people dont agree with it but depending on how badly you want to hit your goal, spend a few hours before going to the track and take out your seats and speakers. For every 100lbs you take out of the car it takes 0.100 off your 1/4 time.
Also, idk how much of a burnout you do, but street tires dont need a "burnout". A nice 2-3 seconds of spinning is plenty to get the tires warmed up and knock the rocks off. Over all it sounds like you are getting good grip, just play with the launch limiter till you get some spin out of it, then feather the throttle a bit and your golden!
08Sivic is offline   Reply With Quote
Old 12-29-2011, 04:48 PM   #10 (permalink)
230whp Club!
yeah i didnt burn out. and i dont power shift.
should i drop my air pressure more? i had 27 in that run.
and i thought 3k rpm launch was to much because all the wheel hop. so your saying boombas wont help much? ill raise it to 4k for next time and try it.
Old 12-29-2011, 04:59 PM   #11 (permalink)
Chimasi's Avatar
Rob
Yea try around a 4500 launch and rather popping the clutch, ride it out slower!!..that'll definietly help with the wheel hop!..I run a Hasport rear mount and a stiffy top dog bone mount for track days and get 0 wheel hop!!..an powershifting 3-4 will help tremendously!!
Chimasi is offline   Reply With Quote
Old 12-29-2011, 04:59 PM   #12 (permalink)
230whp Club!
heres the video. sorry bad quality + kid in the background.
06 CIVIC SI 14.2 pbir (bad quality) - YouTube
Old 12-30-2011, 12:53 AM   #13 (permalink)
08Sivic's Avatar
With more rpm, you'll actually be able to get the tires to spin instead of just hop. Wheel hop is just when the car is at that less than ideal state where it is so close to hooking, but instead of full on spinning, it just hops like a horny rabbit... More rpm, and youll get a little more spin. A little bit of "slipping" the clutch is an idea to try as well, im not a huge fan since clutchs are expensive. Im more of a fan of feathering the throttle instead of the clutch. Thats just me. You have to practice and see whats best for you.
Tire pressure is probably pretty good. 27-30 is usually standard for street tires. I normally run 28 front and 35-40 rear when i run street tires.
The boombas may help a good bit, but one of my buddies with full boomba mounts and full boltons, still hops at the track. Usually its just attributed to the track prep and street tires. Street tires were not made for the track. Plain and simple. Thats why alot of people get wheel hop at the track.
Hope this info helps. Good luck to ya!
Old 12-30-2011, 01:19 AM   #14 (permalink)
230whp Club!
i thought i was launching to hard! thanks, now i know i wasnt launching hard enough!
but i had a 2.2 60' so how much better can i honestly do launching at higher rpms which will cause me to spin and slow me down theoretically. it seems now i need to focus more on up top power since my 60' is where it needs to be
Old 12-30-2011, 02:53 AM   #15 (permalink)
ran 14.13
civic si at zmax dragway ran 14.13 - YouTube
lol this video again? haha
power shift like this
Old 12-30-2011, 08:26 AM   #16 (permalink)
^^vid not working
Old 12-30-2011, 09:15 AM   #17 (permalink)
civic tech's Avatar
13.7@102
just wait for a really cold night. Your driving is just fine. Its gonna be difficult for you to get into the 13's with street with only a 98mph trap speed. A cold night should give you the extra ponies that you need.
civic tech is offline   Reply With Quote
Old 12-30-2011, 12:43 PM   #18 (permalink)
230whp Club!
it was about 50 degrees out in palm beach florida. (sea level).
i just want to know if its attainable to hit 13.9 on my setup... untuned with a 60mm.
next time im gonna try to launch around 3500 or 4000. but what about tire pressure. is 27 to much. i think 20 would help my launch but hurt my overall time.
Old 12-30-2011, 12:47 PM   #19 (permalink)
Rich
reduce as much weight,particularly in the rear as possible and bump up your rear tire pressure to 45-50 plus play with front tire pressure. You could also try to preload your suspension by slightly dragging the clutch (while staged) and holding the e-brake and squeezing the gas slightly.You'll maintain better traction if you let the weight ease off of the front tires rather than popping back from dumping the clutch.
R3TARD3D pacman is offline   Reply With Quote
Old 12-30-2011, 02:07 PM   #20 (permalink)
civic tech's Avatar
13.7@102
Run factory tire pressures. Lowering the pressures on your radials will not help. you will actually lose contact patch and hinder traction. I never ran in the 13's on street tires but did run a 14.01, and that was with basic bolt ons as well. i actually increased my tire pressure to help with top end. I was trapping just over 100 mph.
New at tuning AFR; could use some pointers korrupted Hondata 6 02-21-2013 11:51 AM
drag race pointers beeroge1020 Autocross & Sanctioned Drag Racing 11 02-22-2009 05:37 PM
ANY POINTERS WHILE S/C install frankdatank85 Supercharging 11 09-04-2008 11:56 AM
Heading to the track tonight...need some pointers... roadrunner1659 Autocross & Sanctioned Drag Racing 10 04-04-2007 11:35 AM
Mike Phillips formerly of Meguiar's gives us a few pointers... Yospeed Garage 2 03-14-2007 05:29 PM
