Old 01-25-2007, 06:09 PM   #1 (permalink)
Rocco's Avatar
stockFA5 VS BB6 Prelude w/ CAI, Header, Catback, StageII clutch, short throw shifter?
anyone know the outcome of this battle..or any guesses...i think i would get it handed to me at the track??????
Rocco is offline   Reply With Quote
Old 01-25-2007, 06:26 PM   #2 (permalink)
qwerty :)'s Avatar
kyle
probably...it might not be horrible, but it wouldnt be good for you lol
qwerty :) is offline   Reply With Quote
Old 01-25-2007, 07:05 PM   #3 (permalink)
Rocco's Avatar
hahah...
Old 01-25-2007, 11:12 PM   #4 (permalink)
udumkid's Avatar
Rene....
97 Prelude Specifications
Engine & Transmission
Body & Chassis
Configuration
Aluminum-Alloy
In-Line 4 Weight
2954 lbs.
Valvetrain
Belt Driven 16-Valve DOHC VTEC Length
178.0 in.
Displacement
2157 cc Width
69.0 in.
Power
195 @ 7000 rpm Height
51.8 in.
Torque
156 @ 5250 rpm Wheelbase
101.8 in.
Bhp / Liter
88.67 Front Track
60.0 in.
Bore
3.34 in. Rear Track
59.6 in.
Stroke
3.57 in. Steering
36.1 ft
Redline
7400 Body / Frame
uni-body
Compression Ratio 10.0:1 Spark Plug Gap 0.039-0.043 in.
Camshaft Lobe Height
Prelude
Intake: Primary 1.3402 in.
Mid 1.4510 in.
Secondary: 1.3768 in.
Exhaust: Primary 1.3285 in.
Mid 1.4300 in.
Secondary1.3655 in.
Prelude Type SH
Mid 1.4657 in.
Mid 1.4450 in.
Secondary1.3655 in.
Gear Type
5 speed Front Brakes
power assisted self -adjusting vented disc
1st Gear Ratio
3.285 Front Pad Surface Area
7.391 sq-in. x 2
2nd Gear Ratio
1.956 Rear Brakes
power assisted self-adjusting solid disc
3rd Gear Ratio
1.344 Rear Pad Survce Area
4.32 sq-in. x 2
4th Gear Ratio
1.304 Front Wheels
16x6.5 alloy
5th Gear Ratio
.812 Rear Wheels
16x6.5 alloy
Final Drive Ratio
4.266 Front & Rear Tires 205/50 R16
Differentail
Open Suspension
Independent double wishbone, coil spring wiht stabilizer
Vehicle Identification Number
1,2,3 Manufacturer, Make and Type of Vehicle JHM: Honda Motor CO., LTD Honda, Passenger Car
4,5,6 Line, Body and Engine Type BB6: Prelude, H22a4
7 Body Type and Transmission Type 1: 2-Door Coupe/5-Speed Manual
2: 2-Door Coupe/4-Speed Automatic
8 Vehicle Grade (Series) 4: Prelude
5: Prelude Type SH
9 Check Digit
10 Model Year V: 1997
11 Factory Code C: Saitama Factory in Japan (Sayama)
12-17 Serial Number Starts with 000001 (I have 000094)
Paint Code
Paint Code Color
B-83M Nortic Mist Metallic
G-83P Eucalyptus Green Pearl
NH-592P Flamenco Black Pearl
R-94 San Marino Red
Stock Performance
Top Speed 140 mph 0-60 mph 6.6 sec
1/4 Mile Time 15.4 sec 0-100 mph 17.9 sec
Lateral Acceleration n/a EPA City/Hwy 22 / 27mpg
its a drivers race. Race him and see what happens..come back and post who won.
udumkid is offline   Reply With Quote
Old 01-25-2007, 11:46 PM   #5 (permalink)
bLaCkAnGeL07's Avatar
Justin
Damn. Those things are a beast. I never realized they were that fast.
bLaCkAnGeL07 is offline   Reply With Quote
Old 01-25-2007, 11:52 PM   #6 (permalink)
KingMarineM16a4's Avatar
David
You would lose.
KingMarineM16a4 is online now   Reply With Quote
Old 01-26-2007, 12:08 AM   #7 (permalink)
2000civic's Avatar
Robert
I call drivers race. Ludes are not incredibly fast.
2000civic is offline   Reply With Quote
Old 01-26-2007, 09:32 AM   #8 (permalink)
Shark Tek's Avatar
Neither the SI
He will lose pretty bad no doubt about it. (Assuming that both drivers are equally good.)
Is like a SI vs a (I/H/E) SI.
Shark Tek is offline   Reply With Quote
Old 01-26-2007, 10:22 AM   #9 (permalink)
Kakashi's Avatar
You guys forget how heavy the Lude is...
3000+ lbs with driver.
Old 01-26-2007, 01:16 PM   #10 (permalink)
PR_S14's Avatar
Freddy
I used to spank modded preludes with my I/H/E S14 and there was no way my car was a 14 sec car.
But really, it always depends on the driver.
PR_S14 is offline   Reply With Quote
Old 01-26-2007, 05:19 PM   #11 (permalink)
You win. You have the better powerband.
Old 01-26-2007, 05:25 PM   #12 (permalink)
20strong's Avatar
Marcus
AMEN to the powerband. Its all about the torqe curve.
20strong is offline   Reply With Quote
Old 01-26-2007, 06:01 PM   #13 (permalink)
A lot of people just look at the specs but the performance K-series' have a better power curve than H22's (or any B-series motor). Doesn't make THAT huge of a difference in a straightline, but the torque does.
Old 01-26-2007, 06:11 PM   #14 (permalink)
Kakashi's Avatar
I dunno Tee.. ive seen some seriously high compression SH's.. man those things took off
Old 01-26-2007, 06:33 PM   #15 (permalink)
The SH's are a different story. Them bishezzz move, for their weight.
Old 01-26-2007, 06:41 PM   #16 (permalink)
Louder than 4 F404-GE-400
Paul
the Si and the driver weigh in at over 3000lbs too. I raced a lude that had I/H/E in my GSR that had an I/H/Highflow cat/E and a grounding kit an i lost by half a car length after we both had good lanches. So i'd say the Si "should" win unless you can't drive.
Old 01-26-2007, 08:05 PM   #17 (permalink)
07CivicSiRacer's Avatar
Tommy
FA5 here.. i've raced a 03 RSX-S w/ CAI/RH/E and spanked it by 2 cars or so.. RSX-S's launches are horrible.. and he have beat a 00 Prelude w/ i/h/e by (oh lord, 3 cars maybe?).. so i say the Si should move on the Lude.. just my thoughts.. btw.. my mods are injen intake, comptech short shfiter when i raced him (now i have a DCRH).
P.S. factory HP & TQ doesnt conclude how quick the car is.. there's many things such as.. weight, driver, launch, shift, powerband, etc. and most FG&FA owners do pretty well w/ all of the above i've listed. some reason, k-series owner tends to PWNED most cars.. K-power FTWWWW!!
07CivicSiRacer is offline   Reply With Quote
Old 01-26-2007, 08:18 PM   #18 (permalink)
udumkid's Avatar
Rene....
yup,it all depends on the driver. Just look at my race between my 1.5 sohc hatch vs a mitsubishi evoluiton with I/E/down pipe.
http://video.google.com/videoplay?do...48788811282960
Old 02-09-2007, 07:00 AM   #19 (permalink)
civic_06_si's Avatar
yeng her
preludes are as fast as integra gsr. gsr still wins the prelude though. but si. stock to stock no competition. si will walk on it anyday. Trust me full bolt ons and will be as fast as you stock. if drivers are equally good. your car is still new and the prelude is old. all those bolt ons and only gain the hp and torque that it lost, over the long years of passing owner to owner.
civic_06_si is offline   Reply With Quote
Short throw shifter SilverEX Civic Coupe And Sedan 9 09-24-2006 12:38 PM
