Jordan Denmark
Went to the Track!
so i went to the track for the first time ever...basic FA5 with an AEM short ram. my best run was like 10.1 at 71 mph. said my friend who watched the board.
any advice to make this faster without adding parts? like good track strategy or shift timing or something? also on my second run first gear popped out...? dont know why but i wasnt going that fast yet. anyone know why this happened? |
That is why it popped out. That wheel hop is a VERY bad thing. You will start to break things if you wheel hop, you will snap motor and trans mounts, you will snap axles, you will blow transmissions. Next time it 'hops', get out of the throttle immediately.
Well, its hard to avoid it because at a drag strip, there is a ton of sticky rubber that has been left on the track. This causes a lot more 'grip' than if you were to launch on bare pavement. Honestly, you'd probably have to avoid wheelspin on launch, which is a slow way to launch, or get upgraded motor mounts.
Yes, its from increased traction combined with lots of engine movement. The OEM mounts are really soft, so when you increase grip, the engine jerks back and forth on the launch, and this is the result. I get a bit of wheelhop just from running sticky tires, I can only imagine how much worse it must be when you are launching on a surface that is 1 inch thick race rubber.
#11 (permalink) |
Anthony Copertino
thats how i hurt my transmission, when i brought it to the dealership they thought it would be a good idea to beat on it while driving it...essentially destroying the final drive and starting a 3 month long dispute! I got my way though, wheel hop is your worst enemy
#13 (permalink) | |
Well, what brand/model/size tires are you running. You won't necessarily see any benefits from dropping pressures in the OEM Michelins. The best way to turn faster times is the driver mod.....practice, practice, practice. |
#14 (permalink) |
invsta
do. not. run. slicks. on. your. stock. civic. You will destrooooy everything. Let a little bit of air out of your stockies, and for god sakes, learn how to feather the clutch so that you don't burnout like a noob.
#19 (permalink) |
invsta
thx testify. OP, you're basically slipping the clutch, but in a good way. As you practice, your feather will last shorter and shorter until you can launch at maximum velocity without burning out. Perfection comes as you know your car better.
| Have boosted car thats track ready? Drop me a line to be in a track comparison | illycut | Forced Induction And Nitrous | 37 | 02-13-2010 02:17 PM |
| TRACK Junkies, What TIRES suit you best..[City/Track] | SpeedDemon | Wheel And Tire Upgrades | 58 | 07-24-2009 02:13 PM |
| Shannonville Track day (Full Track) - May 16th 2009, Saturday eveni | agentragex | Ontario | 139 | 06-05-2009 05:10 PM |
| New Track in KC?????? | RogueDawgVill | Mid-West | 9 | 07-19-2007 02:08 AM |
| Want to track my stock Si, what mods/advice i need my fellow track junkies? | AznSupastar | Autocross & Sanctioned Drag Racing | 16 | 12-24-2006 04:08 PM |
