Drag Radials good or bad? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Autocross & Sanctioned Drag Racing
Old 08-22-2011, 11:57 PM   #1 (permalink)
Silverbullet07's Avatar
Isaiah
hello everyone. i know a few things as the difference between drag radials and slicks. so ive been told slicks are better and id rather have them. BUT i got a few set of slightly used drag radials for cheap. Kumho v710, hoosier r6 and hoosier a6 is what i have just to let yall know.
my main concerns are breaking an axle. i dont care what time i get as long as i dont break anything anybody with an si that are using drag radials or slicks that can chime in. just wanting to get good advice from people with a first hand expierence. also let me know what would be the best launch control setting plus tire pressure to set them at. thanks guys! jotech and other shop cars be sure to chime in!
Originally Posted by Strate L O S S Idk my vtech goes ring and pulsates too.
Originally Posted by Strate L O S S you mean 2 more doors for 2 more whores
Silverbullet07 is offline
Old 08-23-2011, 12:28 AM   #2 (permalink)
None of those tires are drag radials.... their sidewalls are way too stiff.
JDMThoughts is offline   Reply With Quote
Old 08-23-2011, 12:33 AM   #3 (permalink)
Isaiah
uhh? okay? thank you for your educated comment
i know that AJPs civic has like 500 hp and launches at 6 grand and they havent had any problems so ive heard
Silverbullet07 is offline   Reply With Quote
Old 08-23-2011, 12:44 AM   #4 (permalink)
fishermoe14's Avatar
R18 FTMFW
wuts your mod list like?
fishermoe14 is offline   Reply With Quote
Old 08-23-2011, 12:52 AM   #5 (permalink)
Isaiah
CAI,header,3inch catback, boomba mounts, and flashpro.
Old 08-23-2011, 12:55 AM   #6 (permalink)
R18 FTMFW
i dont think youll have to worry about breaking axles and such..
Old 08-23-2011, 02:01 AM   #7 (permalink)
Brandoff's Avatar
brandon smith
I agree, you'd need a bit more tq to worry about those axels breaking. unless you launch like a jackass.
Brandoff is offline   Reply With Quote
Old 08-23-2011, 02:10 AM   #8 (permalink)
Chimasi's Avatar
Rob
I'm in for some expierienced answers!!...Curious as to what kind DR's to use with a all motor setup an how to lunch wit them!!
Chimasi is offline   Reply With Quote
Old 08-23-2011, 06:58 AM   #9 (permalink)
Isaiah
Yeah I think y'all are right. There won't be any launching like a jackass lulz
Old 08-23-2011, 10:45 AM   #10 (permalink)
Edwin
Same mods as you listed above and I used bf goodrich drag radials 20 psi launched at like 4200 feathering clutch got a 2.1 60 ft so there is room for improvement but I ran 13.7 @102 but on one of my runs when I shifted into second clutch started slipping bad because of the grip so be careful
rdrgzfam is offline   Reply With Quote
Old 08-23-2011, 12:17 PM   #11 (permalink)
Chimasi's Avatar
Rob
Still trapping at 102 Thats damn good!!..I have a Comp Clutch stage 2 that I wanna put to the test!!
Old 08-23-2011, 12:38 PM   #12 (permalink)
Isaiah
my clutch started slipping about 4 weeks ago (95k) and it would onnly do it when i got on the car hard. hopefully it wont get worse on me ill try to take it easy on the clutch. but i really think it has a small bad spot in the flywheel. but now the clutch hasnt slipped in like a whole week and ive been trying to make it slip. BUT im saving up for a clutch plus i got a competition clutch 50% off coupon then ill be pairing it with a lightweight flywheel.
ill post up some times in a couple weeks. too bad its a 1000ft track
Old 08-23-2011, 02:06 PM   #13 (permalink)
Chimasi's Avatar
Rob
I got mine paired with the 8lb flywheel and love it!!
Old 08-23-2011, 04:46 PM   #14 (permalink)
hatch's Avatar
Eric
Originally Posted by Silverbullet07 View Post
uhh? okay? thank you for your educated comment :facepalm
What he's telling you is correct. All the tires you mentioned are R-Compound tires intended for autocross or road race use and they do have stiff sidewalls designed for cornering. A drag radial or slick designed for drag racing has soft sidewalls designed for straight line performance.
I auto-x on R6's and ran them at the drag strip one day thinking they would be better, but honestly I think they were worse than my normal street tires. It could have been me thinking they should perform better than they did and over driving the car , but I ran slower times. I wouldn't recommend them to someone who is going out to buy tires specifically for drag racing. If you already have them you can give them a shot, other wise I'd look at drag radials, I'm sure they can be found used for cheap also.
hatch is offline   Reply With Quote
Old 08-23-2011, 06:55 PM   #15 (permalink)
Bboy_Burst's Avatar
Ku
you don't have to worry about breaking axles with a bolt-on Si
Bboy_Burst is offline   Reply With Quote
Drag radials on steelies? Chimasi Wheel And Tire Upgrades 5 08-12-2011 01:30 AM
Warming up drag radials lviey001 Autocross & Sanctioned Drag Racing 21 07-22-2010 01:39 AM
Should i get drag radials for the SI tvmendoza Wheel And Tire Upgrades 10 02-19-2008 08:06 PM
