speed is way off in 1/4 mile - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Autocross & Sanctioned Drag Racing
Old 06-15-2011, 02:03 PM   #1 (permalink)
devin
i am getting weird mile an hour on the top end
time were
rt .042
60' 2.3
330' 7.1
1/8th 9.34
1/8 mph 81
1000' 12.0
1/4 14.3
mph 108
what the am i doing wrong? i think the car should be 13 something with that mile an hour
all_go2008 is offline
Old 06-15-2011, 02:04 PM   #2 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
What gear you ending in, and what rpm?
FijiBlueFG2HT is offline   Reply With Quote
Old 06-15-2011, 02:10 PM   #3 (permalink)
12.81@113 jrsc'd street tires
a 14.3 should be 98-100mph. what track did you go to?
stallion07 is offline   Reply With Quote
Old 06-15-2011, 02:25 PM   #4 (permalink)
Ryan410's Avatar
Ryan
you could do 12's with that mph. what are your mods...you must be spinning your arse off the line.
Ryan410 is offline   Reply With Quote
Old 06-15-2011, 02:40 PM   #5 (permalink)
civic tech's Avatar
13.7@102
either you are spinning through the 1/8 mile or the clock malfunctioned.
civic tech is offline   Reply With Quote
Old 06-15-2011, 03:04 PM   #6 (permalink)
K20Z3allmotor's Avatar
12.423 @ 109 mph No AC jaja
time were
rt .042
60' 2.3
330' 7.1
1/8th 9.34
1/8 mph 81
1000' 12.0
1/4 14.3
mph 108
8th mile looks correct, trap is pretty high for a 14.3
K20Z3allmotor is offline   Reply With Quote
Old 06-15-2011, 04:58 PM   #7 (permalink)
devin
it was at toronto motor sports park in kohler ontario and i have a injen cold air intake greddy 2.5" cat back spec 2 clutch , custom 6.5 lb fly wheel running a flash pro base tune for the injen intake on 02 rsx type s 16 " rims the air fuel ratios were really rich too like 11:1 and i know the 60' is bad but i dont think it was spinning to bad i have the launch limiter rpm at 3500 after i got into second it does chirp third and 4th
all_go2008 is offline   Reply With Quote
Old 06-16-2011, 04:38 PM   #8 (permalink)
The clock must have been off. There is no way you are trapping 108 with those mods. Based on your 60' the clock was off as well. If you ran a 14.3 @108 your 60' would've been around a 2.6-2.8.
3.Slow6MT is offline   Reply With Quote
Old 06-16-2011, 04:46 PM   #9 (permalink)
bulliedog's Avatar
Its probably KM not MPH in Canada!
Whipple W100ax Twin Screw SC'd 09' Fa5 454 hp/300 tq@19.5psi
My Whipple W100ax Twin Screw Build Thread
My 2.3 Whipple Build Thread
bulliedog is online now   Reply With Quote
Old 06-16-2011, 06:03 PM   #10 (permalink)
or that track is just as off as MIR
Old 06-16-2011, 06:16 PM   #11 (permalink)
Strate L O S S's Avatar
you should really remove from fuel from your tune. 11 afr isn't too good.
Strate L O S S is offline   Reply With Quote
Old 06-16-2011, 08:14 PM   #12 (permalink)
bulliedog's Avatar
haters are always gonna hate!
Old 06-16-2011, 09:43 PM   #13 (permalink)
bouncer07's Avatar
Gnehp Gnoix
2.3 60 ft and still finish off strong with 108mph. Must be tail wind.
bouncer07 is offline   Reply With Quote
Old 06-16-2011, 09:47 PM   #14 (permalink)
bulliedog's Avatar
With those mods there is no way he had a 108 mph trap speed! It should be more like 98 mph.
Old 06-16-2011, 10:35 PM   #15 (permalink)
Mitch [Ryan #3]
Op has secret nos button
Old 06-17-2011, 12:41 PM   #16 (permalink)
JeankySTi's Avatar
Jean Colon aka Jc
Clock is most likely off, he layed down 27mph from the 1/8 to the 1/4 that is turbo car status. For example the Black Widow which is a wild all motor setup traps 96mph on the 1/8 and 116 on the 1/4 that is just an 20mph gap.
JeankySTi is offline   Reply With Quote
Old 06-24-2011, 04:24 PM   #17 (permalink)
devin
i have leaned the car out since then but have not gone back yeat to see what a difference it made and no there is no nitrous on the car and yes it is mile an hour not km/ph weather the clock is off or not i am not sure but hope fully will find out if it ever stops raining here
Old 06-28-2011, 07:45 PM   #18 (permalink)
DecepticonDC5's Avatar
David Yingst
too soon junior
DecepticonDC5 is offline   Reply With Quote
Skunk2 Shift Knobs: 5 Speed & 6 Speed WeSellCarParts WeSellCarParts.com 1 09-01-2011 11:54 PM
(Oklahoma) OK-Speed.com Festival of Speed - 2010 lolevo South 7 05-06-2010 01:14 PM
Display Speed vs Actual Speed csxian Wheel And Tire Upgrades 6 06-08-2008 11:59 PM
nice 1/4 mile speed/hp calculator. Check this out webby Autocross & Sanctioned Drag Racing 12 03-26-2006 02:12 AM
