Most logical/cheap rotors/brakes for STX Autocross? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Autocross & Sanctioned Drag Racing
Old 06-13-2011, 10:41 AM   #1 (permalink)
Mjrn.'s Avatar
Ultra Man!
So like a lot of guys involved in autox, I'm not on an unlimited budget but I'm now looking for a way to stop more consistently. I'm running stock everything insofar as brakes, in STX class.
Problem is, I have some grooving and glazing and it's definitely affecting how consistently I can brake, and how much. I plan to bleed the system (pedal feels mushy sometimes) and if I can't upgrade within a reasonable budget, I may live with it, but yesterday I took 1st place but only .3 seconds and I know my fear that my brakes will not stop me has kept me from attacking the course.
So, what would you guys recommend? I want something that's going to work immediately (it is autox, after all) and I won't have to worry about silly things like glazing and grooving (I don't track the car and don't plan to in the near future at all). At this point, to keep costs down, I'm thinking of just replacing those glazing/grooved rotors since it's cheap, easy and stock pads were great in autox! LMK what you guys think (I don't know much about how well slotted/drilled rotors work or how durable they are). TIA!
Here are the rules:
E: STX and STU: Non-standard brake rotors may be used provided
they are of equal or larger dimensions (diameter and thickness) and
made of ferrous material (e.g. iron). Thickness includes the individual
plates of a vented rotor, as well as the overall dimension. The diameter
for replacement rotors is measured at the minimum outside dimension.
Aluminum rotor hats are allowed. Cars originally equipped
with solid (non-vented) rotors may utilize vented rotors. Cross-drilled
and/or slotted brake rotors may be fitted provided all such voids are
within the disc area, and comprise no more than 10% of that area.
Brake calipers and mounting brackets may be replaced provided they
bolt to the standard locations and the number of pistons is equal to or
greater than standard. A functioning emergency brake of the same
type, operation, and actuation as OE must be present. Drum brakes
may be replaced with disc brakes of a diameter equal to or greater
than the inside diameter of the standard drum. Such conversions
must be bolted, not welded, to the axle/trailing arm/upright, and must
include an integral, redundant emergency brake. Changes to backing
plates/dust shields/brake lines to accommodate these changes
are permitted but may serve no other purpose.
Mjrn. is offline
Old 06-15-2011, 10:43 PM   #2 (permalink)
What kind of brake fluid do you use? How often do you bleed or flush?
SIgen is offline   Reply With Quote Quick reply to this message
Old 06-15-2011, 10:44 PM   #3 (permalink)
Mjrn.'s Avatar
Ultra Man!
Never bled since I bought the car in 07 never really was an issue since I just started autox this year. So it's stock fluid DOT 3 I'm guessing?
Mjrn. is offline   Reply With Quote Quick reply to this message
Old 06-16-2011, 02:18 AM   #4 (permalink)
Brake fluid is something that degrades over time and needs to be bled regularly. Brake fluid is actually hygroscopic and absorbs moisture. I usually bleed my brakes a couple times a year, including before autocrosses, and I also do a complete system flush yearly.
Also, upgrade your brake fluid to something with a higher boiling point. ATE Super Blue is a great value for the cost/performance.
Old 06-16-2011, 07:15 PM   #5 (permalink)
Also Motul 600 is a good brake fluid. for autox or track.
JSCJosephC is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
LinkBack to this Thread: http://www.8thcivic.com/forums/autocross-sanctioned-drag-racing/259537-most-logical-cheap-rotors-brakes-stx-autocross.html
Cheap Slotted Brake Rotors This thread Refback 06-19-2011 03:23 PM
HFP Rotors and Brakes Fernando Suspension and Brakes 2 05-15-2011 10:44 PM
What brakes and rotors to get? aznsyco Suspension and Brakes 6 05-10-2011 06:42 PM
What Brakes To Get???? and Rotors 360bin Suspension and Brakes 15 01-28-2011 10:03 AM
Where to buy brakes and rotors? kgbwnet Ontario 5 03-25-2010 03:08 PM
New brakes and rotors AkinaGod Suspension and Brakes 7 02-26-2008 10:55 PM
