Dead space on brake pedal for Civic LXs - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Autocross & Sanctioned Drag Racing
Old 04-04-2011, 06:54 PM   #1 (permalink)
Is that normal?
Had it since I bought the car.. the 1st inch or so pretty much does nothing on
the brake pedal. Drove my friend's Si the other day and found his w/o the
dead space.
Just wondering if it's normal and if there's a way I can get rid of it?
Thanks!
JT-KGY is offline
Old 04-04-2011, 07:07 PM   #2 (permalink)
dank6sp's Avatar
Austin Buttz
Originally Posted by JT-KGY View Post
Is that normal?
dead space.
Thanks!
That is not good or normal I'm not sure of the exact spec but rule of thumb should not be more than half an inch of pedal free play on the brake pedal and sounds like it needs adjustment, or it's possible you might have the wrong fluid in the system
dank6sp is offline   Reply With Quote
Old 09-12-2011, 01:42 PM   #3 (permalink)
RuckinCivic's Avatar
could also mean the difference between disc and drum brakes....disc all the way around i prefer....my lxs has rear drums...i fkn hate it....
RuckinCivic is offline   Reply With Quote
Old 01-25-2012, 12:23 PM   #4 (permalink)
I took my car into the shop the other day and noticed a similar thing on my brake pedal (not sure if something has actually changed or it's one of those "when you get something done you start noticing things that were already there" things).
When the car is off, pumping the brakes builds up pressure and it remains firm when pressed, but after the car is on and the vacuum is on, I need to depress the brake about 1" in order to keep the car from moving when not in park. I hear the "click" of the electronics go on and the brake light goes on after about 1/4" of movement. The pedal reaches a "stop" with clearance to spare above the floor, and it doesn't "sink", it just feels like it takes longer for it to engage.
Scrima is offline   Reply With Quote
Dead Pedal on 2009 Civic - Removable? investingdad Civic Coupe And Sedan 5 11-10-2008 08:04 PM
HLEP PLEASE!!! Replacing stock dead rest pedal to JDM FG2 Sport Dead rest pedal bigpun07 Inside and Out 11 11-08-2007 08:38 AM
