DIY: Skunk 2 Mega Power Header Install - Page 2 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > 8th Gen Civic TECH Exchange > Articles - Engine, Other
Old 07-23-2011, 02:45 PM   #21 (permalink)
Admin Ninja
obert's Avatar
obert
Originally Posted by 07siMike View Post
Hey I was wondering where you picked up your new spring bolts from? or did you order online
I bought them from a honda parts place online
Old 07-27-2011, 01:11 PM   #22 (permalink)
WyoSi's Avatar
Ben
Awesome DIY. Just one question, as I haven't gotten my alpha yet but assume no instructions will come with it, what are the torque specs on the header bolts?
And is the secondary O2 bung further back making it better for an O2 reading form all 4 cylinders?
WyoSi is online now   Reply With Quote
Old 07-27-2011, 01:15 PM   #23 (permalink)
Admin Ninja
obert's Avatar
obert
I would have to look up the specs because I dont remember, I am running my air/fuel gauge in that bung.
Old 07-27-2011, 01:25 PM   #24 (permalink)
WyoSi's Avatar
Ben
That makes sense! I'll probably put my factory O2 sensor there until I get a wideband and then I'll switch them around. I'm guessing you see very similar results between your wideband in the secondary bung and your factory O2 sensor (through flashpro)?
And I'll take a look and find the torque specs, I'm sure they are around.
Old 07-27-2011, 01:32 PM   #25 (permalink)
Admin Ninja
obert's Avatar
obert
The stock senors was alittle off from the AEM one but I guess some people have seen it be way off from the aftermarket one.
Old 07-27-2011, 03:25 PM   #26 (permalink)
WyoSi's Avatar
Ben
I just got my Alpha header, looks like the location of the "primary" makes it rather useless for me. So I'll weld on another bung close to the existing "secondary" so that I can read the same exhaust stream with them both. Better to do it now before I install it, otherwise I'd have to take it off again to weld it on.
But I see you aren't using the defouler that came with the header, my understanding was that it just tricks the secondary into thinking that the Cat is still there right? It's best to just install the A/F sensor without it correct?
Thanks!
Old 07-27-2011, 03:35 PM   #27 (permalink)
Admin Ninja
obert's Avatar
obert
So I am running the flash pro and I have the secondary o2 sendor disabled. There is no need to use the defouler on the air/fule gauge sensor.
Yeah the defouler keeps the sensor out of the full stream of the exhaust to keep a cel from showing up. If you don't have a flash pro then you do need to use it on the stock o2 sensor.
Old 07-27-2011, 05:29 PM   #28 (permalink)
good right up. always wondered how this was gonna be done. dont have an 8th gen yet but it was just weird to me with the motor sitting backwards
oxweeblexo is offline   Reply With Quote
Old 07-27-2011, 05:44 PM   #29 (permalink)
Admin Ninja
obert's Avatar
obert
Thanks........
Old 07-29-2011, 03:07 PM   #30 (permalink)
tougEMII's Avatar
**DAVID**
i was gonna ask if you were throwing a cel with the defouler but your using flashpro.....soo nvm. if anyone has this header and not running fp, is your cel light on with the defouler, cause mine is
tougEMII is offline   Reply With Quote
Old 07-29-2011, 03:19 PM   #31 (permalink)
Admin Ninja
obert's Avatar
obert
Witch one do you have it on ?
Old 07-29-2011, 11:50 PM   #32 (permalink)
Pentabubs's Avatar
Brendan
so i don't need power tools for any of this install, correct?
as for injecting my stock motor mounts also, those DO need to be re-torqued with air tools??? My friend has an air compressor w/ power tools that ive done lots of other car stuff with, but we apparently can no longer use his garage... so im wondering if i can get away with doing all of this with just basic tools
Pentabubs is offline   Reply With Quote
Old 07-30-2011, 01:34 AM   #33 (permalink)
tougEMII's Avatar
**DAVID**
everythings where it should be. defouler is on secondary bung, primary o2 extended to defouler and secondary o2 to primary bung. reset my ecu after i added the header than 100 miles the cel popped up
Old 07-30-2011, 02:14 AM   #34 (permalink)
Will06SI's Avatar
Function over Form..
Your primary should not be plugged in too the defouler,the defouler should be plugged in too your secondary O2 sensor.
Will06SI is offline   Reply With Quote
Old 07-30-2011, 03:21 AM   #35 (permalink)
Admin Ninja
obert's Avatar
obert
Yeah you can do this install with just hand tools, no power tools needed.
I would try to switch the o2 sendors around and reset everything and see if the works. What ever you do just leave the defouler in that secondary bung. Let us know if switching them works. I am running the flash pro so I don't even have my secondary hooked up at all and the primary is in the primary bung and my air fuel gauge sensor is in the secondary bung. (I really hate this part of the header, this is were people disagree on here the o2 sensors should go)
As far as I have read the way he has it set up right now is how it should be done. I was told never to put the defouler in the primary bung hole. The way he has it now and what you are telling him he would have to put the defouler in the primary bung hole. That is why I told him he should try to switch the o2 sendors back and leave the defouler were it is.
Old 07-30-2011, 03:41 AM   #36 (permalink)
Will06SI's Avatar
His defouler is in the secondary bung where the extended primary belongs..
"defouler is on secondary bung, primary o2 extended to defouler"
Old 07-30-2011, 03:58 AM   #37 (permalink)
Admin Ninja
obert's Avatar
obert
Yes thats why i told him to switch the o2 sendors back and try that.
Old 07-30-2011, 04:04 AM   #38 (permalink)
Will06SI's Avatar
You figure with the countless threads on this he would have got it right the 1st time..
Old 07-30-2011, 04:09 AM   #39 (permalink)
Admin Ninja
obert's Avatar
obert
Yeah this is the worst part of installing this hader and now the Alpha header. Skunk2 says one way and then other people say the other way. Some people have no problem with having the header hooked up like skunk2 says and then people do.
It should be one way and one way only !
Old 07-30-2011, 04:26 AM   #40 (permalink)
Will06SI's Avatar
I know its ridiculous at this point i am waiting on the mentioned O2 extension to be made then ordering a new O2 sensor and hopefully i never have to talk about this topic again.
LinkBack to this Thread: http://www.8thcivic.com/forums/articles-engine-other/260507-diy-skunk-2-mega-power-header-install.html
Articles - Engine, Other on 8th Generation Honda Civic Forum | BoardReader This thread Refback 09-17-2011 08:23 PM
skunk mega power vs. Greddy ti-c si2k7 Exhaust Discussion 55 04-11-2012 10:39 PM
Skunk @ mega power/Vibrant Header Schmecs08si Header Discussion 4 01-14-2010 11:17 AM
Comptech or Skunk 2 Mega Power R?? Tomoyuki Bolt-Ons And All-Motor 13 03-22-2007 01:05 AM
