8th Generation Honda Civic Forum - View Single Post - DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System)
View Single Post
Old 02-22-2008, 12:03 PM   #161 (permalink)
BigMoney8481
BigMoney8481's Avatar
Randy
My amp does not have an auto-on feature so i had to run the acc. It all depends on the company's specifications.
The amp you have is probably not designed to run at 8ohms. That's why it is not listed in the specifications. If you run it at 8ohms successfully than you are going to have <300wrms to your alpine.
Just run it at 2ohms. It says 100Hz b/c this is signal where the power rating was taken from and where they calculated the thermal distortion. It's fine. Hook it up and let 'er rip.
BigMoney8481 is offline   Reply With Quote
